Dr Forinor
Noisy clutch
When the car is cold and I press the clutch pedal, no noises at all, but when the car has been driven for a while and I press the clutch pedal, you hear a spring being pressed and depressed, you dont notice as you drive around but everytime I park up in the garage after a run I hear it.
What is it and does it mean anything?
Sounds like the return spring on the pedal, sometimes they make a noise like you describe. Worth a look
my golf vr6 also does it,sounds like its coming from the slave cylinder.Its been like it a while (2 months) so maybe i should take it to the vw garage .
Mine has been doing this, started about a fortnight after having clutch and slave cylinder replaced., sounds to be coming from under bonnet as opposed to pedal.
Odd, the way I see it is, it must be just the diaphram spring itself or the release bearing just squeaking on it, I assume you changed the spring and pressure plate and release bearing, and not just the clutch plate itself? Not that I'm worried about the noise but.. its just a bit strange :S
yeah i'm not too concerned about the noise yet, i had john at JMR do a serious amount of work at the same time (chains tensioners, cluch etc etc ) so not sure exactly if he replaced release bearing etc, but i'm sure he would of done if he deemed it required. going back to him soon ish to give my bank account another battering so i'll get him to look then.
My car does exactly the same since i bought it 2 years ago...
Although the clucth and everything works great!
I wouldn´t mind about that, i´ll wait until the time to change the clutch!
I'm thinking the same, I just wanted to make sure it wasn't anything serious, even though it doesnt sound that bad.
