4stud
hydraulic tappets
Hi guys,
How much are a set of these and how easy are they to fit? Got all the tools just need some info on them. The car is a 2l 16v k reg.
Craig.
14537 CAM FOLLOWER-HYDRAULIC CO 2.0 >95 6.50
Thats what i can find on there site. Any good?
I wasthinking of doing mine too, Im just gonna see how much they are. Anyone know what theyre like to change on a VR? Is it a big job?
These are the oly ones on there:
14535 CAM FOLLOWER-HYDR 1.0>1.6 95> 8 & 16V ENGINES(roller rocker arms) 4.50 Add
14537 CAM FOLLOWER-HYDRAULIC CO 2.0 >95 6.50 Add
Is the second one compatible for aVR?
Or these from eurocarparts:
RUVILLE 311440031 HYDRAULIC CAM FOLLOWER PO/GO/JE/VE/PA/L.T./A80/A100
Hydro follower £6.50
My tapping noise went today.
Now i'm even more worried! No oil light on but have i/did i lost/loose pressure?
Actually dont answer, as long as it's running right i dont care!
Tappets quite sensitive to dirty oil sometimes in a higher mileage engines because so much "dirt" gets into the oil unlike a new/low mileage engine.
Use oil flush additive at the next oil change (not flushing oil!), drive a few miles rather than stand it idling as per the instructions and just change the oil following that.
Which oil is best? it has 15w 40 semi syn in it at the mo but it's only halfords own. Also do you have to worry about the oil filter in the later 2l 16v's? VW/Bosh filter?
Craig
Oil is already discussed, search. Summer 15w40, winter 10w40.
16v oil filter is free er flowing than the 8v but for normal driving, the difference is little.
