g60rado
Idle Screw & ISV
After removing my boost return piping and my isv, I cant get my g60 to idle without holding the gas pedal down. If i unlug the outlet where the isv was connected and put the isv back on (without plugging in the harness) it will start and idle fine.
Where is the idle screw located exactly, i have an idea, but it doesnt seem to be doing anything. ANy ideas why it wont idle when the ISV outlet from the throttle body is plugged?
is it on the back of the mainfold pointing in towards the car, behind the throttle cable? That's the one i was turning.
its at the back of the throttle body and the place it goes into feels like it should have a pipe on it no a screw in it, the head of the screw should be just sticking out. its a pain to adjust and i would get it out and replace the o ring on it.
