Taggart 0 Posted August 31, 2005 Is there anything else I should replace while doing my rear shocks. I'm just going to keep it as is and replace with GSF shocks. Quote Share this post Link to post Share on other sites
davidwort 0 Posted August 31, 2005 Is there anything else I should replace while doing my rear shocks. I'm just going to keep it as is and replace with GSF shocks. bump stops may be pretty worn, you can replace the other mounting rubbers from VAG fairly cheaply too, but it doesn't really make any difference as they don't wear badly. David. Quote Share this post Link to post Share on other sites
Taggart 0 Posted August 31, 2005 Cheers, will look into. I suppose another q won't be out of order on the same topic, Which of these should I go for from GSF? 45639 SHOCK ABS BQ GAS RE CO VR6 8/91 > 28.00 Add 45639A SHOCK ABS GAS RE CO VR6 8/91 > 22.00 Add 45639AG SHOCK ABS BQ GAS RE (GEN) CO VR6 8/91 > 27.00 Add Quote Share this post Link to post Share on other sites
davidwort 0 Posted August 31, 2005 Cheers, will look into. I suppose another q won't be out of order on the same topic, Which of these should I go for from GSF? 45639 SHOCK ABS BQ GAS RE CO VR6 8/91 > 28.00 Add 45639A SHOCK ABS GAS RE CO VR6 8/91 > 22.00 Add 45639AG SHOCK ABS BQ GAS RE (GEN) CO VR6 8/91 > 27.00 Add get the Best Quality ones, not sure but would suggest the (GEN) item, whatever you do don't get boge uprated gas ones, I did this on my valver and they were rock hard. David. Quote Share this post Link to post Share on other sites
