turbocorrado
g60 conversion need help
in the process of fitting the engine from my crashed g60 into my valver does anyone have any information on wiring diagrams etc help would be appreciated
cheers
You should buy yourself the Bentley manual for the Corrado. Everything is in it.
Really there isn't much to know providing you can put all the lpugs back where they came from then it should be dead easy.
You will need to sort out the fuel pump though. 16V runs a higher pressure than G60. No need for the accumulator either.
Gavin
