GazzaG60 0 Posted October 12, 2005 put a wideband up it. it wont blow up at idle so you need to see the fueling at higher rev/load pints too. Quote Share this post Link to post Share on other sites
goodridge 0 Posted October 12, 2005 ian,i have a gas aniliser me self :D can you tell me the correct procedure for this? sorry to be on such a crap/boring subject here :( neil. Run the car up to temp. Disconnect the blue temp sensor and block the breather ( if your boost return isn't already removed ) This puts the ECU into its 'setting mode' Adjust the CO to spec, using the CO pot, can't remember spec of the top of my head, im sure someone will confirm. Once set rev the car 3 times above 3000rpm. The ECU will then learn this setting. Recoonect blue temp sensor, and breather if applicable. Job done. Quote Share this post Link to post Share on other sites
gibber 0 Posted October 12, 2005 Riley let me know if you want a hand mate, and we can do my G60 at the same time! Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted December 29, 2005 Neil, did you ever get this sorted mate...?! Quote Share this post Link to post Share on other sites
Riley 0 Posted June 25, 2007 Neil, did you ever get this sorted mate...?! Thread ressurection. Nope :( :shock: Can't believe im still having this fecking problem after all this time...21 months? :( Although a little progress has been made... If i tape up the WOT switch,the problem (slow revving and popping) totally dissapears... What this means i don't know. Quote Share this post Link to post Share on other sites
Riley 0 Posted June 25, 2007 Just emailed The brain (Mr cresswell) via the golf+ magazine... Quote Share this post Link to post Share on other sites
potatonet 0 Posted June 25, 2007 what happens with your car again, 25 pages is a lot to read through Quote Share this post Link to post Share on other sites
Riley 0 Posted June 25, 2007 Aye,can appreciate that m8 :lol: Once warm...it intermittently pops when hitting the throttle,and its slow to rev. Tape the wot switch closed and all is well. Neil. Quote Share this post Link to post Share on other sites
ziderapple 0 Posted June 25, 2007 Just emailed The brain (Mr cresswell) via the golf+ magazine... Cut out the middle man, PM him: Crasher Quote Share this post Link to post Share on other sites
potatonet 0 Posted June 26, 2007 new wot switch? Quote Share this post Link to post Share on other sites
W3RKD 0 Posted June 26, 2007 27 pages and you still haven't checked the AFR ?? Quote Share this post Link to post Share on other sites
potatonet 0 Posted June 26, 2007 I agree with darren... get AFR gauge hooked up ASAP Quote Share this post Link to post Share on other sites
Riley 0 Posted June 26, 2007 With all due respect guys...it could have been said a lot earlier in the thread...and i don't know of anybody around my way that could check it. Ive asked for reccomendations on who could look at it but im always told g-werks who are a million miles away.Plus money is an issue,so it would have to be someone who can possibly do me a favour,or help out as cheaply as possible. Neil. Quote Share this post Link to post Share on other sites
potatonet 0 Posted June 26, 2007 50 USD for an AFR gauge that looks stock isnt a bad deal. duostyling.com Quote Share this post Link to post Share on other sites
ninoG60 0 Posted June 26, 2007 I think hes already had one of them duostyling gauges on it . Quote Share this post Link to post Share on other sites
Riley 0 Posted July 11, 2007 Put the carbon cannister back on in a false sense that it may cure this... It didn't. But now i have the big bangs out the exhaust on quick gear changes like i used to...car is also not starting first time...its always the second go that it starts. Quote Share this post Link to post Share on other sites
potatonet 0 Posted July 11, 2007 My car always starts on the second go... putts a bit on the first go. change the ECU yet? Quote Share this post Link to post Share on other sites
Riley 0 Posted July 11, 2007 Yep,here's a list of everything ive changed. Fuel filter. ecu. chip. head gasket and all new exhaust/inlet gaskets. Valves reground/re-seated. New cam belt/tensioner and static timing spot on. all sensors inc lambda. ign timing bang on 6deg btdc. co pot. Injector loom. Injectors (as of today) Injector seals and caps. pipe 1 meter long to ecu. Spark plugs from vw £70 feckin quid! Spark plug leads/dizzy cap/rotor arm. Dizzy itself. New throttle body gaskets. New throttle body switches. All earths cleaned up with emory and replaced. Alternater. Voltage regulator. fpr. Probably more that ive forgotten... Quote Share this post Link to post Share on other sites
potatonet 0 Posted July 11, 2007 um slow to accelerate and popping during acceleration is normally caused by timing being off... someone could have marked it wrong..... normally running lean if you are retarded on timing...? I think thats right, tape the WOT switch and the computer wants to dump more fuel, 02 sensor fixes this but if you hit the gas more, the fuel should dump in there. really think its the timing here, YOU NEED TO CHECK THE AFR!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GET A GAUGE !!!!!! Quote Share this post Link to post Share on other sites
craigowl 0 Posted July 12, 2007 Dont know anything about G60s or AFRs, but what about a fuel filter change? Didnt see it in the list. Apologies if it has been changed - and Good Luck, Riley. Quote Share this post Link to post Share on other sites
DanVW 0 Posted July 12, 2007 Just a thought but if the problem gose away with the WOT switch taped up I wonder if the switch cable is shorting when the WOT switch is open? Would be worth checking with a meter from the switch itsself to the ECU end of the loom, just in case the ECU is getting the idle value untill you hit WOT! again sorry if you have already tried this just chucking ideas in hope you get it sorted mate cant imagine how pissed with this you must be by now!! Cheers Dan Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted July 12, 2007 get your wallet out stop messing about and take teh car to a specialist,, this has gone on too long,, earths lambda wiring, o2 sensor knock sensor, crank pulley bolt, fule pressure, fuel pump wiring harness, everything needs to be checked,, bet its something glaringly simple,, Quote Share this post Link to post Share on other sites
potatonet 0 Posted July 12, 2007 Im with the fuel filter guy after looking at symptoms of a bad fuel filter. Quote Share this post Link to post Share on other sites
Riley 0 Posted July 12, 2007 Just a thought but if the problem gose away with the WOT switch taped up I wonder if the switch cable is shorting when the WOT switch is open? Would be worth checking with a meter from the switch itsself to the ECU end of the loom, just in case the ECU is getting the idle value untill you hit WOT! again sorry if you have already tried this just chucking ideas in hope you get it sorted mate cant imagine how pissed with this you must be by now!! Cheers Dan Thanks Dan,this is the kind of post i like to read. Is it something that could happen? get your wallet out stop messing about and take teh car to a specialist,, this has gone on too long,, earths lambda wiring, o2 sensor knock sensor, crank pulley bolt, fule pressure, fuel pump wiring harness, everything needs to be checked,, bet its something glaringly simple,, Sorry m8,but i think you fail to appreciate my position here...Ive spent around 1k trying to sort this... Ive been to garages who have wrongly diagnosed it time after time...Most costly was when i was told it was a sticking valve...so to save labour charges i took the head off and reseated everything myself.Can you imagine how p|ssed off i was when it fired up first turn of the key still doing it? Spent countless late nights trying to figure it out... Im in debt,and ive had to give up work due to illness. So simply getting the wallet out is not an option. :? Everything you mention has been checked,except for the knock sensor...which when unplugged dosn't cure it.If it was something so simple...im sure someone somewhere off the forums would have found the cause by now. What do you think to Dans suggestion above? Im with the fuel filter guy after looking at symptoms of a bad fuel filter. Fuel filter changed :( will add it to the list. Quote Share this post Link to post Share on other sites
potatonet 0 Posted July 12, 2007 Niel think about it like this. you arent getting enough fuel, sooooo WOT wiring to ECU could be busted...? like the guy said idle fuel till WOT is opened then it dumps fuel. fuel injector wiring harness busted? that would make sense too. but the car would sound like it was running 3 cylinders. Quote Share this post Link to post Share on other sites
