Supercharged Junkie 0 Posted September 7, 2005 Hi Had John at JMR change the guide roller on my car when he fitted the ported T/B(Which is great :-) ) but ever since theres been a consent squeak coming from it, Pretty sure its not the belts, but looking at it closely looks like the guide roller is just touching the tension assembly ? Whats the normal clearance between the top of the guide roller and the tension assembly? Everything looks like its mounted correctly, Is the tension roller the same part no. as the guide roller BTW because when i took to garage before to have them change the guide roller, they changed the tension roller ( Go firgure :mad: ) Any ideas because the consent squeaking is driving me crazy :mad: :scratch: :crazyeyes: Thanks Ian Quote Share this post Link to post Share on other sites
Son of a Beesting 0 Posted September 7, 2005 I had this a while ago, changed the belts, idler pullies and the cambelt tensioner and it sorted it. It was actually the camblet tensioner that was causing the squeeking for me. I presume from your post you changed all these things so I cant really think what else it could be??? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted September 9, 2005 Yeah ive got that currently, is it most noticeable when revging engine slightly or when changing gear? Id put it down to the tensioner pulley. Quote Share this post Link to post Share on other sites
