steveo29
g60..bogs down when cold engine
ive noticed over the last couple of weeks my g60 bogs when the engine is cold...like within 2-3 miles from my house..it will bog/stumble if i take my foot off and re apply after a corner or something
everything checks out as far as i can tell...although i did recently get another sns chip...can anyone confirm if they affect the cold running??
I had a problem with my chip, it was sticking too much fuel in at cold start, if I drove it straight away it would almost stall but was fine after being left for a few seconds, Darren said he'd change it for the newer one next time I was down there (It didn't effect it anymore that the first few seconds tho..)
Have you got the old chip to swap back in?
Ive had a similar prob. When i lift of throttle like coming up to a junction, the revs drop below 800rpm and then it goes back up to normal idle revs. Running a chip myself, its running too rich, have to go get it setup correctly
