VEEDUBBED 0 Posted September 20, 2005 How does 1 go about running low imp. injectors on digi1?,i've got loads of big injectors but i'm limited to using small bosch G60 green tops,i've got 4 '803' green top porsche turbo injectors that i want to use with digi. I heard that you need resitors on the fuel injector's harness,thoughts please. Quote Share this post Link to post Share on other sites
h100vw 0 Posted September 20, 2005 Have you looked at http://www.summitracing.com they sell lots of injectors at very reasonable money. The Ford Motorsport ones for the Mustang are the red tops that everyone goes on about on the forum. http://autospeed.drive.com.au/cms/A_0102/article.html Maybe you can find something useful in this article. Quote Share this post Link to post Share on other sites
keithmac 0 Posted September 20, 2005 The low impedance injectors will probably be in the 4 ohms range, ideally you need to be 14 to 16 ohm per injector. Some people use in series resistors, you`ll need to use quite heavy duty ones and check there temp after a good run. edit, highs and lows.. Quote Share this post Link to post Share on other sites
Chris VR6nos 0 Posted September 21, 2005 Best get the propper ones for the job as failure can result in a lot of hassle and money! Chris Quote Share this post Link to post Share on other sites
