4stud
Rumble and knock
Got a rumble and slight knock in the front left hand corner. Worse when turning right. It's not the wheel bearing as i've done it recently. Could it be the cv joint? Makes a real loud knock when reversing left hand down but only once each time.
Craig.
I get the same problem, I think it is my worn suspension. The spring tries to turn on its plate but because its worn it suddenly jumps into possition making a loud clonking noise.
