R1-Jay 0 Posted October 1, 2005 I'm going to do a flush on the cooling system tomorrow. Whats the best way of getting the old fluid out? is there a hose to undo and let the hosepipe flow water in? Quote Share this post Link to post Share on other sites
Jim 2 Posted October 1, 2005 I'm not sure which model Corrado you have but.. honestly, the coolant change procedure has been documented maaaaannny times. Not often I get to say it but, use the search luke ;) http://the-corrado.net/.archive/forum/search.php Quote Share this post Link to post Share on other sites
lukeage 0 Posted October 1, 2005 Bottom rad hose off - and then drain it all away. Fill with tap water turn engine and then drain again to give it anothe flush. Your now ready to use some G12+ (2 x one and half litres). Top up the remaining with water *EDIT distilled water from halfords. The above was butchered from different threads - been collating them into a spreadsheet of jobs to do. How screwed would i be without this forum - screwed :) Quote Share this post Link to post Share on other sites
stevemac 0 Posted October 1, 2005 Bottom rad hose offRead that as "remove thermostat" Quote Share this post Link to post Share on other sites
