Tekara
How should this go together ?
Hello All
While nosing around the engine bay i noticed a loose heat shield around the rear mount on my VR. There are several cables on a bracket. Could anyone explain how that little lot should fit together? See the attached images.
I am a little reluctant to take the nut off in case its holding it all to the mount. If it is what the correct torque setting.
Cheers
Ross
You can take that 13mm nut off, it is not hold the engine mount, that is the 17 nut on the same stud, you will see what I mean wen you take it off!
gibber, thanks for that. Shield now firmly in place.
Wish garages would put things back together properly.
That would be stupid tho - where would they get all those spare nuts and bolts from otherwise...?
