4stud
Oil pressure light to gauge?
Hello,
Anyone ever put a oil pressure gauge in they're C? I have a 2ltr 16v k reg and would prefer a gauge rather than the light.
Not at all difficult mate,buy gauge from somewere like demon-tweeks and correct sender if your going to use an electrical gauge,run a wire into the car from sender,+/- wires on sidelight circuit for the internal light and a positive ign. controlled wire and bob's you uncle,i've fitted a racetech electrical gauge to my G60 9A valver,very good quality and quite accurate but can be worrying when you cold start the 9A 2.0 as the cold oil pressure goes off the gauge's scale,8+Bar...
So the hardest part is running the cables into the car (as well as giving demon tweeks money). I need a sender from a car with a guage then? Didn't think they would be that different.
