V3DUB 0 Posted October 16, 2005 VR6 calipers look alot bigger than my G60 ones, is there any chance i can use the vr6 calipers on my g60 and keep g60 carriers? its looks like it should work. Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted October 16, 2005 they are the same size,although some vr6 owners have converted to the 288's off the later golfs Quote Share this post Link to post Share on other sites
V3DUB 0 Posted October 16, 2005 they certainly aint the same dude Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted October 16, 2005 vr6 has 280mm discs and the g60 has 280mm discs unless my maths are wrong then they are the same size,the only difference is the vr6 is 5 stud,so the calipers would be the same Quote Share this post Link to post Share on other sites
V3DUB 0 Posted October 16, 2005 yeah they both use the same size disk but to look at the vr6 has alot deeper caliper. Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted October 16, 2005 nope they are both exactly the same, http://www.eurocarparts.com/ecommerce/S ... esults.asp look half way down the page Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 16, 2005 Yep, exactly the same caliper as Dazzy says, unless you are comparing with a late VR Golf with 288's... Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted October 17, 2005 I fitted VR calipers to my G60,identical components on both cars. Quote Share this post Link to post Share on other sites
V3DUB 0 Posted October 17, 2005 unless my g60 has 16v calipers or somthing, the vr has just a flexi pipe going into it, mine have flexi, and then a little copper pipe goin into the caliperand there gold Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 17, 2005 Yeah - thats the early G60 calipers, they changed on the M chassis... Same size as the later ones just a different hose configuration and use a shorter hose with the same fitment on each end... Quote Share this post Link to post Share on other sites
g60griff 0 Posted October 18, 2005 so would the tt 312mm fit on the g60 easy enough? Quote Share this post Link to post Share on other sites
dinkus 10 Posted October 18, 2005 The carriers might do (not sure), but the disks are all 5-stud. I believe Mr. Charged has aquired some 312mm 4-stud disks from somewhere tho... Quote Share this post Link to post Share on other sites
