morpheus20170
Interior light...bulb
Can someone please tell me how you get the bulb out of the main interior light as I can't see and the handbook doesn't say, it doesn't seem to have a plastic holder like the other interior light, the smaller one of the two, it is just laying flat but I can't seem to get to it which is damn annoying.
PLEASE HELP!!
Not 100% sure I understand what you are asking, as far as I know all models have two lamps in the centre of the headlining, the smaller (map light) on pass side and larger (main light) on drivers side. On both, the lens cover just pulls down out of the lining to give access to the lamps. Though if memory serves me rightly, I think the lamp in the main light might be obscured (from removal) slightly by the printed circuit board. hth, if not come back
Sorted thanks, you can do it two ways, either take the clear plastic off and then do it which is the easiest way or take the thing apart from the other end that goes into the roof that is a big waste of time.
Cheers for your help.
Paul
