Greenbat 0 Posted October 18, 2005 Hello Guys, I have got a clutch judder, particularly bad in traffic 1st and 2nd gears. Does this mean the clutch is on the way out? Any remedies for it apart from a clutch change? Cheers Greenbat Quote Share this post Link to post Share on other sites
dig776 0 Posted October 18, 2005 I bought my rado about a year ago and tried to negotiate some money off due to some clutch judder. The owner wouldn't budge and I bugeted to fit a new one. 13.5k later and it is still holding Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted October 19, 2005 It could be due to a broken engine/gearbox mount, or imperfections in the (normally smooth, flat) flywheel surface which you should check if you have a new clutch. Best wishes RB Quote Share this post Link to post Share on other sites
Chris M 0 Posted October 19, 2005 Could be input shaft bearing, its usually the case. But its a gear box strip job. If your clutch isnt showing any sighns of slipping i'd say it was the input shaft bearing. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 19, 2005 Greenbat, what car do you have? Quote Share this post Link to post Share on other sites
mr.ots 10 Posted October 19, 2005 Mine has a bit of judder pulling away from standstill in 1st but it tends to reduce once the car warms up. Quote Share this post Link to post Share on other sites
Greenbat 0 Posted October 20, 2005 Mine is a Mk2 Golf G60. Is I think only happens when the car is hot. Cheers Greenbat Quote Share this post Link to post Share on other sites
markmcie 0 Posted October 20, 2005 When I bought my G60 the owner commented that there was some clutch judder. I took it for a test drive and it seemed to me more like dodgy engine mounts. Brought the car home, replaced all mounts and its fine ever since. Quote Share this post Link to post Share on other sites
corradophil 3 Posted October 20, 2005 I had clutch judder from oil on the clutch. In my car's case it was the rear main oil seal. Check for oil leaks around the bell housing. Quote Share this post Link to post Share on other sites
steveo29 0 Posted October 20, 2005 mine has clutch judder once in a while....with everyday use its fine, but if i park up for like a week in the winter when its all damp n horrible out..the first time i use the car it will judder for the first few junctions...i think maybe the friction plate is holding the damp and it drys out with a little heat from driving its done that for 3-4 yrs and got no worse Quote Share this post Link to post Share on other sites
