dubboy
G60 ABS?
Do all G60 have ABS as standard? I thought they were supposed to but my 92 G60 dosen't have it, as there no light on the dash.
But when I got it, the car was fitted with a tow bar (original owner used to tow his jet ski) so there is a light for that on the dash.
Is the ABS disconnected when a tow bar is fitted.
Right makes sense then that nothing kicks in under hard braking.
Just need to get rid of the light for the tow bar now, as its always on.
dubboy, just look for the connectors at the top of the suspension turrets and the ABS valve block in the engine bay and the fuse/relay block for the fan run on near the expansion tank - if you've not got these then no ABS i'm afraid...
It should have been standard on all G60's but there were supply problems, nearly all facelift (92 onwards with bulge bonnet) models have it but I have seen 2 that don't...
