VDUBBER
Engine problems again
Hey every one hope you can help me with a little problem. Just got a 2ltr 16v and the water temp is reading fine but oil temp is high about 102-104 when crusing and 110 in traffic.
But also every so often when driving it is fine then it will splutter twice then carry on as normal. Could this be a timing problem or ht leads, spark plugs?
It isn't using any water or oil. Thanks for any help
hi mate.
(( delete ur other thread ! :wink: ))
Sounds like a slight miss-fire, maybe you should give the car a bit of a service if you haven't in a while, replace the plugs and leads and do an oil change...see if that helps.
The oil temps seem slightly high but nothing major, the 110 in traffic is unusuall though i think, if an oil filter change does no good maybe you could think about changing the oil cooler?.
oil temp is fine
if your worried get an oil cooler, mocal do a really good kit,
but like i said there fine, i get upto 114 with cooler fitted,
ben
Thats a big worry off my shoulders cheers for the help. Still a bit annoyed about the spluttering though i was told the car had just been surviced before i got it and the oil filter looks new. It has just had a new timming belt to could it berunning slightly out of time?
Thanks again for any help
