toddster900
Oil Pressure
My oil light keeps coming on and i cant figure out why. I have checked the level and it doesn't appear to be loosing oil. The only things i could think of were that the sensor is faulty or that it is loosing oil into the water system but that also seems clear.
Any one know anything obvious i am missing?
check the state of the wires onto the oil pressure switches... they can fray or oxidise at the connector causing dodgy readings...
Otherwise, change the 2 oil pressure switches, they're not expensive and will rule them out of the problem... ;)
cheers. just bought the car and not got any mauals yet so i take it the are obviously positioned. never get to see the thing in the light which is not too helpful.
which engine has your C got? The oil switches vary in position depending on engine type.... ;)
ah, one of the 2 engines fitted to Corrados I've no experience of... :roll: :oops: I'm sure someone will be along shortly to help though... 8)
