ollster 0 Posted November 19, 2005 im just changing the front wishbones on my 2l 16v corrado, could someone please confirm for me the tourque wrench setting for the front and rear pivot bolts on the wishbones. For the mk2 16v the front pivot bolt is stated to be 130 nm and and an american document i have states the corrado slc to be 70nm! which doesnt sound right at all... HELP!!!! Quote Share this post Link to post Share on other sites
Ronan 0 Posted November 19, 2005 I think the SLC is a VR6 unless I'm mistaken so the torque settings would be different? Quote Share this post Link to post Share on other sites
RW1 0 Posted November 20, 2005 please confirm for me the tourque wrench setting for the front and rear pivot bolts on the wishbones. For “Basic Running Gear” only. (All EXCEPT Corrado VR6) Front = 130Nm ( 96 lb ft) Rear = 130Nm ( 96 lb ft), (I assume you mean the one through the bush vertically) For “Plus Running Gear” only. (Corrado VR6 only) Front = 50Nm (37 lb ft) then a further quarter turn Rear = 70Nm (52 lb ft) then a further quarter turn, (I assume you mean the one through the bush vertically) SLC = VR6 as said above, so that’s correct. . Quote Share this post Link to post Share on other sites
ollster 0 Posted November 20, 2005 cheers mate thats good news as i ended up using 130 for both of them :D Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted November 20, 2005 So what do I do with mine. Plus VR6 set-up on G60...??? Jay Quote Share this post Link to post Share on other sites
RW1 0 Posted November 20, 2005 Hello Jay, VR6 set-up as you presumably have fitted the VR6 struts as well as the wishbones. The torques are suspension fitted determined, not engine size. Give us a wave some time as you pass a prestine white Scirocco going the other way. Bridge Lane one morning last week going to Hazel Grove. Chris Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted November 20, 2005 Will keep my eyes peeled for you Chris. But the torque settings are for the rear bolts are into the body so do I tighten them to VR6 or G60 as I have a VR6 subframe on a G60 body. I just did them up damn tight! :) Jay Quote Share this post Link to post Share on other sites
RW1 0 Posted November 20, 2005 Jay, They are much the same as I spotted a bit of small print “then a further quarter turn”. So the body ones work out at 70Nm + qtr turn on the VR6. The odd one is the rear furthest back sub-frame directly into the body. That’s just 65Nm, no additional turn angle for a VR6 but all other Corrados it’s 80Nm. So damm tight is most likely OK and not worth a change. VR6 or G60? Use VR6 settings. . Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 22, 2005 Cheers Chris - I'll add the above info to the torque thread... Quote Share this post Link to post Share on other sites
