smiff
Distributor Cap
Does anybody know the life expectancy of the Bosch Dizzy cap on a 1.8 16Valver?
I do recall replacing my current one about 5 years ago. I was very pleasently surprised with the performace and running of the car after it was fitted.
I must have put at least 40K miles on her since. I do have good leads and plugs and was considering spending a few quid before the worst of the weather.
She runs OK, but I have some money to spend on her, kind of a preventative purchase :roll:
I replaced the complete unit, rotor arm and all.
The arm was well worn and if I remember rightly lots of flakes of metal fell out when I opened it up.
Perhaps a cheap and quick fix would be to look at the arm and only replace that if it's needed.
They're not too expensive, might be worth changing it anyway, and like Chris the Mountain says, change the rotor arm too. :D
Yeah.. they don't cost a lot even from the stealer. Might as well do the lot whilst you're at it :)
I'd change the dizzy cap, rotor, spark plugs & spark plug leads.
I change the whole lot on mine every year - just to be on the safe side.
