cymru-corrado
speedo stopped working
the speedo on my clocks stopped working this morn.
had the bulb on the fuel/coolant temp dial changed y'day so suppsoe its something to do with that.however it was working on way home y'day and this morn for a bout 2-3 miles then stopped working,my rev counter is working fine though.
also the illumination for the rear screen heater stopped today.
This hard to get sorted or just probably a loose part somewhere.
ps did do a search mods before you beat me with a stick. :wink:
take out clocks and go down the road watching your speedo cable rotating,if it is, its the speedo head, if it doesn't turn its the...yip you guessed it :-P
Make sure the cable are connected correctly in gearbox and speedo end.
non digital mate,
1990 16v
if its not your speedo cable,i have a spare set of 16v clocks,you can try.
i think your local as i have seen your car about.
if your interrested drop me a pm
regards kevin
