B DUB 0 Posted December 11, 2005 Recently had my fusebox changed and about a month later my corrado g60 cuts out when u change into 3rd and 5th gear ??? any boby got a clue? had new leads/plugs /dizzycap/rotar arm ...... Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 11, 2005 Why was the fusebox changed - you checked for loose plugs / relays? Quote Share this post Link to post Share on other sites
steveo29 0 Posted December 12, 2005 ive noticed if i fit the weight that goes on the gear linkage, its awfully close to some wiring. maybe get a mate to check while you move the gears and make sure its not tugging the wiring harness Quote Share this post Link to post Share on other sites
B DUB 0 Posted December 12, 2005 Cheers mate ill try it .i changed the fusebox as when i got the car the l/hand headlight fuse was melted in . Quote Share this post Link to post Share on other sites
