matth76 0 Posted December 14, 2005 I'm getting my head gasket and chains done plus a 6 branch exhaust manifold. Would I have to run it in for about 500 or is it 1000 miles? I'm assuming I should not go over 3000revs until this is done? Thank you for any help. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 14, 2005 No running in required on those items. I would recommend you use the solid polymer upper pad and corresponding tensioning bolt. I would also recommend after fitment of the new chains and pads, turn the engine over a few times with no plugs in it and the crank sensor disconnected before putting the manifold back on etc. And then recheck the timing. This will ensure that A) there is sufficient oil pressure in the tensioning bolt and B) the engine doesn't kick back and cause the chains to skip a tooth. You might want to do the clutch whilst you're down there too and only use a genuine VW one as aftermarket ones can cause juddering. If you can stretch to £75 exchange for a new flywheel, I'd highly recommend that aswell. Quote Share this post Link to post Share on other sites
dinkus 10 Posted December 14, 2005 2cc's mind-bogglingly detailed Wiki article is worth a read too :) Quote Share this post Link to post Share on other sites
matth76 0 Posted December 16, 2005 No running in required on those items. I would recommend you use the solid polymer upper pad and corresponding tensioning bolt. I would also recommend after fitment of the new chains and pads, turn the engine over a few times with no plugs in it and the crank sensor disconnected before putting the manifold back on etc. And then recheck the timing. This will ensure that A) there is sufficient oil pressure in the tensioning bolt and B) the engine doesn't kick back and cause the chains to skip a tooth. You might want to do the clutch whilst you're down there too and only use a genuine VW one as aftermarket ones can cause juddering. If you can stretch to £75 exchange for a new flywheel, I'd highly recommend that aswell. Thanks for your replies guys. How would my car feel with a new flywheel? Quote Share this post Link to post Share on other sites
Lippy 0 Posted December 16, 2005 it will fly and do wheelies :D hungover in work, sorry :( Quote Share this post Link to post Share on other sites
matth76 0 Posted December 16, 2005 lol Bad luck mate...being in work that is. At least it's Friday though. Quote Share this post Link to post Share on other sites
