Dom!! 0 Posted August 19, 2003 I have just bougth a G60. After a week of having it the termostat on the car dose not seem to work. Any idea what to do with it and how to fix it. :?: Thanx Quote Share this post Link to post Share on other sites
stevemac 0 Posted August 19, 2003 Easy way to check your thermostat is to run your engine untill hot and then feel the radiator - if it's still cold then your thermostat isn't opening properly. Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted August 19, 2003 thermostat is in waterpump. not sure how big a job thermo is but a water pump change is quite a biggie. im doing it this weekend. tis alt, charger,PAS pump off/out of way for a starters Quote Share this post Link to post Share on other sites
G60Jet 1 Posted August 19, 2003 Could be an air lock, you'll need to change the it if its not working and i'd replace it with the 180 degree F version. and while you have the coolant out drop in a new low temp fan switch. Quote Share this post Link to post Share on other sites
Dr. Evil 0 Posted August 22, 2003 Haven't you got a Fiat? :?: Quote Share this post Link to post Share on other sites
