danp
Removing disk - butchered fixing screw...
Swapping pads and disks today but found that the fixing screw for the disk has been mutilated by some1...so any suggestions as best way to remove it (and the disk) pls ?
Guess will try a chisel etc then drill it out unless any good ideas ?!
Cheers, Dan
you can get kits that contain various reverse threaded bits that you can drill a hole for, screw in and then carry on screwing to remove the original screw (if that makes any sense at all). I think halfrauds sell them for about a fiver?
You don't need the fixing screw - it causes more problems than solves really. Just leave it off then you won't have the problem again.
Bolt extractors are PONY. I tried ti use these but made a huge mess as the screws get left and are not replaced. Better to leave them off - does no harm.
:thumb right:
