rayb74 0 Posted December 20, 2005 I got a fault with ABS Outlet Valve (Right rear). Could anyone explain its function and where it is located ? Thx Quote Share this post Link to post Share on other sites
dr_mat 0 Posted December 20, 2005 It's in the ABS valve block, which is the thing with all the brake lines coming out of it under the bonnet. Most likely means a replacement valve block is required .. ABS failure is an MOT failure. Quote Share this post Link to post Share on other sites
