PhatVR6 0 Posted December 23, 2005 hydraulic. I have another head full of them worth a try I suppose. it really is running like a complete dog, it's as lumpy as hell. I'll take the cams out completely and try the leak down test. So much for going up to my parents for xmas :-( Quote Share this post Link to post Share on other sites
h100vw 0 Posted December 23, 2005 Could be one of the tappets is staying pumped and preventing the valve from seating. Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted December 23, 2005 what would cause that? Quote Share this post Link to post Share on other sites
h100vw 0 Posted December 23, 2005 Bad luck mainly I think. CVHs used to do it if you revved them too hard, it jammed in more oil than could escape. The tappet pumped up and held open the valves. All kinds of popping and banging went on until engine speed dropped enough for the oil to drain. Old TomB had similar trouble on his 16V but the tappet went solid for some reason, the piston hit the sticking out valve and punched the cam off the head. It lifted the bearing cap off!!! It's all guess work until you find the cause though. A quick over-rev might have caused a valve to touch a piston, doesn't take much to stop it seating 100%. I would imagine that they are pretty similarish inside to a KR. VW IMHO are just reinventing engines that they started with 30 years ago.. :lol: You're an accomplished mechanic Paul, you'll get to the bottom of it. Gavin Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted December 23, 2005 There's certainly been no valve/piston contact at all. it's so bloody frustrating! Quote Share this post Link to post Share on other sites
h100vw 0 Posted December 23, 2005 Apart from looking a bit mucky both pics look ok. Have you had the cams out to see if the valves are closing? I wonder if a broken/weak valve spring would stop the valve from sealing properly yet not cause any contact? Gavin Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted December 23, 2005 when the head was off I gave the cam a full rotation so i could see that they were closing, and also to see what the seats were like when they were open. couldn't "see" anything untoward. Quote Share this post Link to post Share on other sites
h100vw 0 Posted December 23, 2005 Now we are clutching at straws then. :( You still need to do the leak down, is that right? I think that'll be the decider. Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted December 23, 2005 yeah, I'll do that first thing in the morning. if I can't decide what's happenign the head is coming off again. I still have the original head. I'll clean that up and fit that. Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted December 26, 2005 sorted it! it was a broken exhaust valve spring!! it'll take me all day to write down how I found that out, and how I replaced it without removing the head again, but if you want to know, say so and I'll do a write up. I got a write up on 24v cam timing to do too. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 26, 2005 Cool! - yep, write-up please! Quote Share this post Link to post Share on other sites
h100vw 0 Posted December 26, 2005 it was a broken exhaust valve spring!! Get in! Nice one Paul. Tell us all. Gavin Quote Share this post Link to post Share on other sites
