steveo29 0 Posted December 28, 2005 my g60 still has randomly bad shifting...somedays its close to perfect and others its nasty ive tried ajusting the cables etc, circlip is there, oil is fresh mt90 i figured i might try some 2nd parts on it....do vr6 gearstck and gear selector parts swap/same as g60?? its just ive heard people sa vr6's shift nicer than g60s Quote Share this post Link to post Share on other sites
RW1 0 Posted December 28, 2005 The nicer shift on VR6 is more likely to be the shift weight. Has yours got it fitted. http://the-corrado.net/.archive/forum/viewtopic. ... 5&start=15 Bottom of the first page is the parts list & diagram. . Quote Share this post Link to post Share on other sites
steveo29 0 Posted December 29, 2005 well...i do have the weight, oddly i prefer the feel without it the weight doesnt expalin why its randomly, like i said one minute its fine then next juntion or whatever i cant select first or it get jammed in reverse i wondered if the selector bit was worn ..no one can tell me if theyre a easy fix Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 29, 2005 All G60's i've driven are notchy and all VR's are silky smooth... No idea why but there must be a reason... (I have the shift weight on mine but it's different to the VR ones I've seen...) Quote Share this post Link to post Share on other sites
steveo29 0 Posted December 29, 2005 i cant believe no one has any experiance beyond ajusting cables/? Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted December 31, 2005 Hi steve,i'm running a passat TDI 02A box in my 2.0 G60'd corrado,i also fitted a spare VR6 shifter in place of the worn G60 version,my gearbox also has the shifter weight fitted,the gear change is still slightly notchy,not a lot but it's still there... Quote Share this post Link to post Share on other sites
steveo29 0 Posted January 1, 2006 is the g60 and vr6 shifter identical?? i might have a look for a low milage replacement from a crashed car Quote Share this post Link to post Share on other sites
