willwoll100 0 Posted December 29, 2005 First off MERRY CHRISTMAS and HAPPY NEW YEAR :D Ok now the humming noise is on all the time when the car is stationery and its coming from the rear around the fuel tank area. If it is the fuel pump is it a straight forward job? Where is the best place to get a replacement other than a stealer and how much would I be talking for one? I've had a look on GSF and Euro but can't seem to find a pump??? Cheers Will Quote Share this post Link to post Share on other sites
vwcvr6 0 Posted December 29, 2005 Not sure but it could be the central locking pump ! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 29, 2005 What engine is it? GSF do sell pumps for most VW's I think... When was the fuel filter last replaced - when they get clogged up they can make the pump noticably noisy... Quote Share this post Link to post Share on other sites
willwoll100 0 Posted December 29, 2005 Its a 1994 VR6, and the fuel filter was replaced very recently. Where's the central locking pump situated? My CL isn't the strongest in the world, sometimes it won't open but only very occasionally Cheers again PS would the noise be happening if the ignition was just turned on if it were the CL pump? Quote Share this post Link to post Share on other sites
steve_16v 0 Posted December 29, 2005 Definately the fuel pump if it starts humming as soon as you turn the ignition to position 3 and then stops when you switch off the ignition, mine's made a noticeable humming ever since I've had it and various mechanics have said it's fine. No idea about the location of the CL pump though. Quote Share this post Link to post Share on other sites
willwoll100 0 Posted December 29, 2005 Yeah I'm tending to lean towards the fuel pump as I can't understand why the CL pump would be continuously on??? So any ideas as to how much a fuel pump would cost? Should I just leave it? Will Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted December 29, 2005 sounds like the fuel pump , have you had a feel of it when it makes the noise , you should feel the vibration the cl pump is in the boot on the right hand side behind the carpet but i'm sure this is only active when you use it hth paul Quote Share this post Link to post Share on other sites
steve_16v 0 Posted December 29, 2005 VR6 fuel pump is £113.86 exc (£133.79 inc VAT) from Eurocarparts, but they're out of stock at the moment. Quote Share this post Link to post Share on other sites
vwcvr6 0 Posted December 29, 2005 my cl pump was humming even when switched off and then burnt out :mad: Quote Share this post Link to post Share on other sites
dinkus 10 Posted December 29, 2005 The fuel pump sounds like a high pitched whine all the time and will be coming from the bottom of the fuel tank on the right hand side. If you look under the boot carpet, there's a black hatch that covers it - if the sound's coming from there then you're looking at £70ish for a new pump, probably more if you need the sender too. The central locking pump is behind the rear door card on the driver's side and makes more of a 'moo' kinda noise :lol: Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted December 29, 2005 The central locking pump is behind the rear door card on the driver's side and makes more of a 'moo' kinda noise are you sure ? i'm fairly sure mine is in the boot on the right hand side behind the carpet in a polystyrene box Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted December 29, 2005 The central locking pump is behind the rear door card on the driver's side and makes more of a 'moo' kinda noise are you sure ? i'm fairly sure mine is in the boot on the right hand side behind the carpet in a polystyrene box yep,the window control module lives behind the drivers side rear card not the cl pump Quote Share this post Link to post Share on other sites
dinkus 10 Posted December 29, 2005 Ah ok sorry. I'll shut up about things I don't know :D Quote Share this post Link to post Share on other sites
willwoll100 0 Posted December 29, 2005 Definately the fuel pump if it starts humming as soon as you turn the ignition to position 3 and then stops when you switch off the ignition, mine's made a noticeable humming ever since I've had it and various mechanics have said it's fine. No idea about the location of the CL pump though. Cheers steve_16v can't believe the bloody price, god knows how much a stealer would want!!! So the next question to be answered is has anyone changed one before and if so is it a simple enough job? Thanks Again Guys Will Quote Share this post Link to post Share on other sites
Walesy 0 Posted December 29, 2005 Just to throw another possibility into the mix, i'm sure I remember a thread about someone having a humming noise from the back and it turned out to be something to do with his heated seats? ..or maybe its a giant humming bird on the rear seat? Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted December 29, 2005 Walesy, yeah you're right mate , thats a screech from the passenger side rear door card , the relay goes mental Quote Share this post Link to post Share on other sites
JoeNose 0 Posted December 31, 2005 I think some low-volume humming can be OK - more than one garage in the past has told me it's pretty normal on VAG cars. Having said that, I replaced the (humming) fuel pump on mine some time back, but found the new pump was silent. However, only a few months later the hum had returned. It's been like like for nearly 2 years now; not down on power and fine to drive. Untill it starts getting really loud I intend to leave it. Quote Share this post Link to post Share on other sites
willwoll100 0 Posted December 31, 2005 Cheers Joe, the car has just been serviced and it wasn't mentioned on the service report but then again the VAG chimps are hardly the best!!! Did you change the pump ok? Any problems and was it straight forward? Will Quote Share this post Link to post Share on other sites
JoeNose 0 Posted January 1, 2006 Car was having a bunch of stuff done in a garage at the time Will, although I hear it's quite straightforward. Quote Share this post Link to post Share on other sites
kongo127 0 Posted January 1, 2006 Once I heard the same humming noise coming from the back when you switch on the elctricals. When you start the engine the problems remains though you cannot heart it very well. So when i opened the boot i could localize where the sound was from. It was the fuel pump which is inside the fuel tank. The noise was getting louder day after day. A couple of days later i couldn´t start the car neither listen the fuel pump switching on with the electrics. I started looking for a brand new fuel pump, here in Portugal i found the better price at the local Bosch Dealer! Hope this helps! Take care os that fuel pump as soon as possible if you don´t want to get stuck on the road just like me! Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted January 1, 2006 I was bored today and it's been raining non stop for 3 days...,so i decided to fit a spare CIS bosch pump inside my G60's pierburg fuel pump housing,i paid nothing for the pump because when i scrapped my old golf 2 i removed it and kept it in a jar of petrol. Anyway,the only time consuming part is trying to see through the petrol inside the tank whilst re-locating the plastic fuel pump housing's pegs located on the bottom of the fuel tank,if you decide to fit a CIS bosch pump in place of the tired O/E g60's version, be sure to get the right model,i.e,the pump that's open at one end and fitted with a fuel filter/strainer,fuel pumps such as the CIS pump fitted to ford escort rs turbos,cossys,porsches etc aren't any good because the pump's got a pick-up pipe meaning that there's no way of fitting a filter,don't worry about the pump being mounted verticaly,i've had no problems so far. Quote Share this post Link to post Share on other sites
kongo127 0 Posted January 1, 2006 That seems ok to me VEEDUBBED, But i got a Bosch Fuel Pump and it looks just like the ones VW are selling. Same fitting. :) Be sure to get a 4 bar pump! And yes... it´s not very easy to fit them when hou have some fuel in tank... Quote Share this post Link to post Share on other sites
