double-6s
more acceleration please!
The 4.2 would be to short, it’s more suited to an 8v. I'd go for the 3.6 really. If you really want a short box though the 3.9 is what you should go for I reckon. Try messing around on an online gear ratio calculator.
You should be able to get a box for about £150.
Here are some figures using Quaife's calculator based on 3.39, 3.68, 3.94 and 4.24 crown wheels. Tyre circumference and rev limit have to be specified too, so I've used 17" Eagle F1s (1872mm) and 6500rpm.
I've simplified it down a bit to show rpm at 70mph in 5th, mph/1000rpm in top and top speed in each gear.
Bear in mind if youre into 1/4 miles, you won't pull 60 in second with the 3.68 and lower diffs without raising the rev limiter to 7000rpm.
3.39
Top Gear gives 24.509 MPH/1000 RPM
70MPH=2856RPM
Top Speed in 1 gear = 35.402 MPH
Top Speed in 2 gear = 63.123 MPH
Top Speed in 3 gear = 91.658 MPH
Top Speed in 4 gear = 129.923 MPH
Top Speed in 5 gear = 159.310 MPH
3.68
Top Gear gives 22.578 MPH/1000 RPM
70MPH=3100RPM
Top Speed in 1 gear = 32.612 MPH
Top Speed in 2 gear = 58.148 MPH
Top Speed in 3 gear = 84.435 MPH
Top Speed in 4 gear = 119.684 MPH
Top Speed in 5 gear = 146.756 MPH
3.94
Top Gear gives 21.088 MPH/1000 RPM
70MPH=3319RPM
Top Speed in 1 gear = 30.460 MPH
Top Speed in 2 gear = 54.311 MPH
Top Speed in 3 gear = 78.863 MPH
Top Speed in 4 gear = 111.786 MPH
Top Speed in 5 gear = 137.071 MPH
4.24
Top Gear gives 19.596 MPH/1000 RPM
70MPH=3572RPM
Top Speed in 1 gear = 28.305 MPH
Top Speed in 2 gear = 50.468 MPH
Top Speed in 3 gear = 73.283 MPH
Top Speed in 4 gear = 103.877 MPH
Top Speed in 5 gear = 127.373 MPH
