quicky1980
What mk2 golf gti 16v can be tranfered over to a corrado?
Ive just got myself a corrado. I alos have a mk2 golf 16v which has lowered suspension, g60 brakes. Aloys. Full ss scorpion exshaust
Just wondering if all these can be swapped over?
cheers
what model corrado do you have?
I think some things off a 16v golf will go on a 16v 'rado. What stud pattern are the alloys? I'm pretty sure that mk2 golfs are 4 stud, so the alloys would go on a valver or a g60 but if you have a VR6, they won't because they're 5 stud.
I don't know about the suspension or the exhaust but I'm sure someone will.....
I fitted a corrado suspesion kit to a Golf. The stuff physically fits but the rates may be wrong for the Corrado.
G60 brakes will go on.
Exhaust no good. Wrong hangars.
Gavin
Just to update this post in case anyone needed the info.
Parts I transfered or found out that I could transfer from a 1989 mk2 golf gti 16v to a 1993 corrado 16v where:
Scorpion Full exhaust system ( from down pipe to rear box) - had to adjust a few hangers but nothing major
Wheels
Suspension
Brakes (G60 Versions)
quicky, were the hanger adjustments cos your 2ltr has bars and the golf has hooks, i.e. do you think the system would have fit straight away onto an early corrado with hook fitments?
Cheers.
iirc I had to cut the middle hanger on one side to clear the exhaust. The rear hanger I used a long bolt and transferred the hanger from the golf. Was a very easy swap anyway.
Just for further info, the exhaust which used to be on the 1.8 16v golf, then went onto the corrado 16v and is now mated up to the vr6 engine i put in not long back. wonder if it will fit the r32 downpipe (planned early 2009) .....lets see
