saysomestuff
Gearbox leaking
Hi all,
Haven't had a chance to have a proper look but there's a puddle under my gearbox, where should I be looking for the source? Any common failures?
Cheers,
Cole
Sure it's the gearbox???? Gear oil, water or engine oil????
If so, four places generally, filler plug on front face, drain plug at the back under the differential bit, around the drive shafts seals above the drain plug on either side of the differential and finally, the gearbox driveshaft input seal inside the clutch bell housing which will show up as a leak dripping off the bottom of the bell housing.
