potatonet
boost return kit
hey guys running a US spec G60 and I have a little sensor that runs off of the gasses coming from the valve cover, it plugs into the 90 degree bend that goes to the boost retrun pipe. if I am re routing my boost what do I do with this little sensor? it does affect the engine if I unplug it.
part number is 037 906 391 its called a heater pipe and is used for cold climates.... yeah its freezing over here right now actually
wow its 126 dollars its gotta be doing something important......
we do not have the plug on the euro looms.. if i remember correctly its for the higher us regs on polution.
well that sucks, so how do I get rid of it? oh wait, I can't... -.-
guesss I will have to move the hose piece and attach it to the line I am going to drop from the ISV down to ground.
some of your euro ones had it, I have euro etka and it has it on there. our US etka doesnt have the other pic shown (straigh pipe).
and If I remember correctly you have to unconnect it when messing with the AFR and then Rev 3 times, so It has something to do with fuel input, probably like G-man said and something like pollution.
