iow_corrado_g60 0 Posted January 23, 2006 hi lads have this really not very nice burning smell today and a few times in past? but its defo not petrol smell! Im a bit worried as obviously you think supercharger is knackered? its only happened a few times before when in 5th! but today I had heating on full heat but the fan power on 0! if that makes sense! and it felt like it was making the smell in pretty much every gear? can someone please advise? could it be the heater matrix? or is the supercharger in bad repair? the boost its running seems fine not quite as high as Id like but not low enough to have a boost leak or broken charger? the charger was rebuilt the end of 03! by jabba sport and has done just under 14k since being re-built! Quote Share this post Link to post Share on other sites
Rustynuts 0 Posted January 23, 2006 Check that the belts are tight enough, could be belts slipping and causing a burning smell. I would doubt it is your charger, can't see how this would give off a burning smell. Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted January 23, 2006 sorry rusty thanks for your reply but ive only had my corrado for 3months how do i check belts do i need to take anything off! could it be the heater matrix? Quote Share this post Link to post Share on other sites
trev-b 0 Posted January 23, 2006 Could be your blower motor, has that been changed? Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted January 23, 2006 it was fiddled with a little while ago before i brought car as the matey actually was getting no hot air? Quote Share this post Link to post Share on other sites
flusted 0 Posted January 23, 2006 ive been in car,it smells like grease burning? its not matrix Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted January 23, 2006 hi flusted yeah i cant remember whether it did it when you came in car but its quite strong at times but then nmost of the time it doesnt happen? it is like a plasticy greasy burning smell bit like flusted said sorry cant describe it never smelt something like it before? Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted January 23, 2006 the matey who had it before had a problem with the heating hot then cold i also know he changed the thermostat over! if this is any help not sure if he replaced blower mtor thou! Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted January 23, 2006 hi flusted said might be oil in inlet as no boost return? thought i just add this? as aide knows alot more than me Quote Share this post Link to post Share on other sites
Trig 0 Posted January 23, 2006 ive been in car,it smells like grease burning? its not matrix So are you saying it 'Smells like greased lightning..'?! ..sorry :oops: :) Quote Share this post Link to post Share on other sites
Guest Posted January 23, 2006 I'd check the belts and see if anything is near your exhaust manifold Quote Share this post Link to post Share on other sites
potatonet 0 Posted January 24, 2006 the smell you are smelling is either being caused by bad valve seals (which I doubt is the case because you would see blue smoke on start up), OR its the oil in, if the car is equipped with no boost return then the oil goes out to the K&N filter which then gets fumey and seeps its way into the heater system, get a carbon fiber scuttle cover or take a piece of acrylic plastic and cut it to fit the full scuttle, the gasses will not get in and you wont have the icky smell anymore, its oil & engine gasses that are making the smell no matter where it is coming from. Quote Share this post Link to post Share on other sites
selbekk 0 Posted January 24, 2006 put an oil catch tank in, see if that helps, and if not, you'll have something shiny to look at ;D So are you saying it 'Smells like greased lightning..'?! *cried and laughed for way too long* Quote Share this post Link to post Share on other sites
potatonet 0 Posted January 24, 2006 grease lightnin' GO GREASE LIGHTNING! Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted January 24, 2006 Potatonet_ OR its the oil in, if the car is equipped with no boost return then the oil goes out to the K&N filter which then gets fumey and seeps its way into the heater system, it does sound like this one! can you please explain it a bit better as what to do as im a total novice potatonet thankyou for answers Quote Share this post Link to post Share on other sites
potatonet 0 Posted January 24, 2006 the engine gasses go out what it called a breather, there is a normal breather output that goes into the boost return system on boost return equipped corrados, this way the funny smell stays in the intake tract. removing the boost return allows this smell to be vented to the air in the engine bay, seepage causes you to smell it because there is a box vent system below the window glass for your car to get air from the outside, cover it fully and you should be good. Quote Share this post Link to post Share on other sites
