Stan 24v 0 Posted January 24, 2006 Will the oil temp/pressure sender for the VR fit the 24v? Or does it need a different one? Ive got some OE gauges for the C, but dont know if they'll work. Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted January 24, 2006 fit the vr6 ones. ditto with the coolant temp sensor. get the yellow one off a vr6 and wire up the 2 wires to it to run the vr6 gauge. Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted January 24, 2006 Cool. Wasnt sure it would fit, as I read it on another forum the other day (I think) well saw it somewhere anyway. Quote Share this post Link to post Share on other sites
kongo127 0 Posted January 25, 2006 You´ll also need to buy a T-Piece to fit your oil sender. You may also use the white/blue wire that ends near the dizzy. This wire is being used, it´s not connected to anywhere. And you won´t need to route a wire from the engine bay to the interior. I did it this way, and it works great! Keep posting! Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted January 25, 2006 What will I need a T piece for? Its the temp and pressure type sender. Quote Share this post Link to post Share on other sites
