Rustynuts
G60 engine fuel leaks
Fuel leak coming from the thermo switch that controls the fuel recirculation. I have checked the pipe and it is all good, i did have to tighten the jubilee clip (the crappy standard ones). However the pressure seems to be too much for it.
Anyone else found this, or could it be something else?
Have you actually changed the pipe?? If not do it, it's standard 8mm fuel hose but make sure you buy the best quality stuff (ribbed) so it won't crease as you bend it into the U shape...
Renew the clips as well as they may have lost theyre thread...
Yeah sounds like a plan, i suppose there could be hairline cracks with fuel coming out. Seems that at times there is more pressure than at other.
