delcfc
Lowering G60 40mm
I'm looking to re-lower my C by 40mm. It was lowered when I bought it but it failed an MOT on one of the front shocks so due to cash shortage I put it back to it's original height. The shocks that were on it were standard. The only thing that lowered it was the springs ?? Wot should be fitted. :?
60mm is quiete a nice drop and comfy and u get the keep all your teeth in place ive just had mine done using apex shocks and springs. Im bedding them in at the mo and its going quite well check the gallery for my pics...(its dropped a bit more since)
40 mm can still be done with only springs... if you want to drop more you should allso change the shocks... (KW gewindefahr or H&R adjustable are very good)
