kebabman 0 Posted February 1, 2006 As I mentioned in another thread, I think my wheels bearings are knackered due to mis-fitting (by me). However I noticed today when driving that if I corner fairly hard on a left hander, the noise goes away, but it doesn't on a right hander....what does this mean? Am I likely to be right with my diagnosis of wheel bearing....a droning noise that increases in pitch with road speed, but not linked to engine speed? Don't want to replace them only to find out it's somtething else. :? Quote Share this post Link to post Share on other sites
buttles 0 Posted February 1, 2006 Classic bearing symptom. Changed a rear only to have it go again very quickly due insufficient grease. :oops: .......and a cr%p bearing to start with....... Quote Share this post Link to post Share on other sites
kebabman 0 Posted February 1, 2006 Ok cheers. :) Does the fact the noise goes in one direction but not the other mean only one side is knackered? Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted February 1, 2006 for the price of the bearing id change both sides Quote Share this post Link to post Share on other sites
2_Door_fun 0 Posted February 1, 2006 Front bearings usually sound whooo whooow whooo. My front pass is wobbling :D well bad new hubs going on this week. Rears grind you hear it and yer heart sinks. Always under load as you corner say left. It unloads the opposite side = no noise. Quote Share this post Link to post Share on other sites
2cc 0 Posted February 2, 2006 Can't see how you'd successfully change fronts yourself unless you have the proper pressing equipment. If you've done it any other way then I'd guess they aren't in true and may account for what sounds like their failure. Quote Share this post Link to post Share on other sites
kebabman 0 Posted February 2, 2006 I'm talking about the rears. ;) Quote Share this post Link to post Share on other sites
AB 0 Posted February 2, 2006 what is the correct torque setting for the rear wheel bearing nut please? Quote Share this post Link to post Share on other sites
kebabman 0 Posted February 2, 2006 There isn't a correct torque apparently, it's just done by feel. Don't seat the bearing that's the mistake I made and they've only lasted 8 months. :oops: http://the-corrado.net/.archive/forum/viewtopic.php?t=36480 Quote Share this post Link to post Share on other sites
andy 0 Posted February 4, 2006 Classic bearing symptom. ....... Definately, classic rear bearing symptom, mine did exactly this. Quote Share this post Link to post Share on other sites
