jamest 0 Posted February 3, 2006 Howdy, having a serious wobbling engine problem in my Mk3 VR6! think all 3 of my mounts have gone... :shock: I paid a local garage £100 to do my front one at first which promptly went again due to the movement created by the back ones. He says that he will do all 3 for £250 (which includes the first one on warranty)... This equals a total £350quid for all 3... AM I BEING RIPPED OFF?! :roll: seems expensive to me cheers Quote Share this post Link to post Share on other sites
steve @ 0 Posted February 3, 2006 Theres a group buy on at the moment on here (waiting for prices). I'd say Your quoted price is a bit OTT. Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 3, 2006 call vag and price the mounts , that seems ott to me if the mounts are fitted and are tightened up without the engine either being rocked or run to seat them correctly then they will work against each other and fail very quickly or pull on acceleration or braking Quote Share this post Link to post Share on other sites
dr_mat 0 Posted February 3, 2006 OEM parts from VW will cost you about £150 for all three, maybe £200 at the outside inclusive of Gordon's council tax. £150 for three hours labour to fit them doesn't seem massively ott though. What's the actual breakdown on that price? Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 3, 2006 They are really easy to fit ,i've done all three on mine and i doubt it took more than an hour Quote Share this post Link to post Share on other sites
-Neil- 0 Posted February 4, 2006 can anyone just give me a very quick rough guide from start to finish on how to change all 3 engine mounts, so i know whether to tackle it myself or not? thanks, Neil Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 4, 2006 a piece of wood on a trolley jack under the sump, jack up the engine to take the load off the mounts , undo (one at a time) the mount , raise the jack til the engine clears the mount and remove , put the other mount in and tighten to the chassis/subframe , lower the engine , either rock the engine backwards and forwards a few times or run the engine and tighten to the specified torque , repeat on all three the most awkward one is the gearbox, just because of the position if you need the torques let me know and i'll dig them out for you to get to the bolts lower down i used two socket extension bars doubled up Quote Share this post Link to post Share on other sites
sparkz 0 Posted February 4, 2006 Is that the same technique for the mk3 vr? Ive got to do my neighbours tomorrow. Its so much easier in a mk2!! Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 4, 2006 sparkz, never done a mk3 but its the same method for most, with it being a heavy engine its important to rock or run the engine before you torque them down , otherwise the work against each other hth Quote Share this post Link to post Share on other sites
lukeage 0 Posted February 4, 2006 GIXXERUK - nice one, often wondered if i could undertake the above. Did you have someone else with you? Quote Share this post Link to post Share on other sites
sparkz 0 Posted February 4, 2006 Cheers gixx, i will remember that!! :wink: Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 4, 2006 no mate , did it myself , you dont really need anyone else tbh Quote Share this post Link to post Share on other sites
matth76 0 Posted February 5, 2006 The Phirm did uprated Vibratechnic ones on my golf vr and they charged a half hour labour mate. Sounds like you're being ripped off especially as you're only getting standard replacements and not uprated. I had my gearbox and front one done (the only ones that really wear on the mark 3 golf) and it cost a little over 200. Worth it in my opinion as they should last far longer than standard ones. Quote Share this post Link to post Share on other sites
