double-6s 0 Posted February 4, 2006 Hi. Can someone please explain, in dumb fella's terms, the difference between the 2.8 and 2.9 vr6s? what is different and where is it? Many thanks. Will OOh, and wher can i get a vr6 crankshaft? :) Quote Share this post Link to post Share on other sites
G 0 Posted February 4, 2006 I dont actualy know the difference but I would imagine the 2.9 has got a slightly higher stroke (distance the piston moves) which is usualy done by having a different crank and not by using different sized pistons/block. This would give different engine characteristics. Quote Share this post Link to post Share on other sites
double-6s 0 Posted February 4, 2006 as far as i know the cranks are all the same so i'm not sure about that? how does a different size piston change the capacity? how is it measured? Quote Share this post Link to post Share on other sites
G 0 Posted February 4, 2006 its measured by the volume of the bore (piston surface area) x the stroke. So a different crank is the easiest way of doing it. Another easy ish way would be to use a different head with slightly more/less area at the top of the cylinder. SOmeone correct me if im wrong though. Thinking about it that second way of doing it might just change the compression ratio Quote Share this post Link to post Share on other sites
G 0 Posted February 4, 2006 I've just done a google search and found on one forum the bloke thinks the bore size is 1mm more on the 2.9. Not sure if its accurate or not though. That is another way of doing it but is abit more difficult for the manufacturer because it means using different spec engine block, head and pistons. Quote Share this post Link to post Share on other sites
G 0 Posted February 4, 2006 lol we know that :lol: Quote Share this post Link to post Share on other sites
veeDuB_Rado 0 Posted February 4, 2006 Sorry, it was the Stella :oops: Quote Share this post Link to post Share on other sites
VWci 0 Posted February 4, 2006 AAA is 2792cc ABV is 2861cc AAAs bore/stroke is 81.0/90.3 ABVs bore/stroke is 82.0/90.3 as you can see bore is different...ABV has bigger bore..... Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 4, 2006 i was told its 1mm extra on the bore , you can rebore a 2.8 to a 2.9 so as above the stroke is the same there are a few ancillary differences such as the TB Quote Share this post Link to post Share on other sites
dr_mat 0 Posted February 4, 2006 .. I'm told the 2.9 also has different inlet manifold and cam profiles. Quote Share this post Link to post Share on other sites
Guest Posted February 4, 2006 yeah the 2.9 manifold and throttlebody are different, the latter makes the biggest difference being of a bigger diameter than the 2.8 throttlebody Quote Share this post Link to post Share on other sites
Pau1 0 Posted February 4, 2006 Nice 2nd post there Bigshow. Loving the new VR6 now are we? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 4, 2006 The OBD1 2.8 and 2.9 throttles are the same bore. The smallest bore is the 2.8 OBD2 stepper throttle. Both 2.8 throttles have a ramp in the throat and a direct linkage. The 2.9 has no ramp and an indirect link to slow down the initial opening, which mimics the behaviour of the 2.8's ramp. The smaller OBD2 throttle and manifold give a better response lower down as the narrower bore speeds up gas flow, which improves torque. Quote Share this post Link to post Share on other sites
double-6s 0 Posted February 4, 2006 ok. can we have some plain english spoken here purleeese! if one had a 2.8 mo fo, what would one need to do to change it into a 2.9 mo fo??? just out of interest. Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 4, 2006 double-6s, do have a dead 2.9 mo fo take rape bits off ?and you want to bore out a 2.8 mo fo btm end ? or do you just have a 2.8 mo fo Quote Share this post Link to post Share on other sites
double-6s 0 Posted February 4, 2006 my two wheel loving friend you understand me exactly. i have a potentially dead 2.9 mo fo, and a worn 2.8 mo fo. idea was to get 2.8 to 2.9 spec without C being off road whilst it gets done. also saw a brand new 2.9 block on the bay. so if i could get that, what would i need to do to the head of the 2.8 mo fo to make it sit atop the 2.9 mo fo block? am i making any mo fo'ing sense???? :) :) :) Quote Share this post Link to post Share on other sites
dr_mat 0 Posted February 4, 2006 2.8 and 2.9 have the same cylinder heads, so should fit together immediately, with no probs. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 4, 2006 LOL! The mo fo VR parts are all interchangable.... the only major difference between 2.8 and 2.9 (other than my throttle and manifold bullschitt) is the mo fo bore. Stick your mo fo 2.8 head on that new mo fo 2.9 block and you're good to mo fo go.... :-) Quote Share this post Link to post Share on other sites
double-6s 0 Posted February 4, 2006 LOL! thanks guys. thats exactly what i wanted to mo foking hear!!!! so basically i can get my 2.8 head rebuilt, get that new block if poss, and the C will only be off the road for a couple of mo fo days? in theory ;) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 4, 2006 Yep, that's the mo fo plan ;-) Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 4, 2006 fo sho mo fo :-) Quote Share this post Link to post Share on other sites
Guest Posted February 4, 2006 Nice 2nd post there Bigshow. Loving the new VR6 now are we? was bored today after i washed the vr, its too reliable, my other vw's always need something done but this one needs nothing. now im stealing this boys thread just to get more posts. Quote Share this post Link to post Share on other sites
double-6s 0 Posted February 4, 2006 off to bid on that block then. cos i'm a 12v man through an through. you can all keep your 24s and r32s mo fo's :) can i just add before the abuse starts........if i had the money i'd be getting a 32!! ;) Quote Share this post Link to post Share on other sites
