Browna_27 0 Posted February 6, 2006 I am looking at buying a suspension for under £300. What do people recommend for this price? Venom look like a good option. With the universal poly bush kit with dust covers they come to £250. What are peoples views on the kit? :) Cheers Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted February 6, 2006 Not heard anything on the venom kits, but personally I'd try and stretch a little further and get some FK AK coilovers... Quote Share this post Link to post Share on other sites
dub envy 0 Posted February 6, 2006 I bough a budget Venom Kit for my G40. Lasted about 10 month sbefore the shocks went all bouncy. Don't do it. Quote Share this post Link to post Share on other sites
Browna_27 0 Posted February 6, 2006 mmm I am thinking the FK AK Coilovers will be better. Sounds like the venom won't last. 8) Quote Share this post Link to post Share on other sites
khurrado 0 Posted February 6, 2006 stay away from budget suspensions. Quote Share this post Link to post Share on other sites
W3RKD 0 Posted February 6, 2006 Woth also considering are the KW non coilover kit -40mm @£350.00 and the H&R cup kit. If you not looking at adjusting the ride height i would go for a set up like this. As these kits are designed by some of the best suspension companies with great results and should yield a far better quailty ride than a budjet coilover. Quote Share this post Link to post Share on other sites
Browna_27 0 Posted February 6, 2006 I like your suggestion Darren, I am not to fussed about height adjustable more fussed about the ride quality. I think though as this a bit more money I will have to wait. Can you get hold of this kit or point me in the right direction. Cheers! :) Quote Share this post Link to post Share on other sites
W3RKD 0 Posted February 7, 2006 I have PM'd you some more infomation Browna_27, Quote Share this post Link to post Share on other sites
tarche2 0 Posted February 7, 2006 I have had 4 of the venom kits one I ran on 80mm drop on my mk2 for about 2 years and run fine! Its actually a GMAX kit. I will def use again!!! Quote Share this post Link to post Share on other sites
khurrado 0 Posted February 8, 2006 ive got a gmax kit. Its a load of horse sh**e. IMO. Quote Share this post Link to post Share on other sites
tarche2 0 Posted February 8, 2006 it appears gmax dont fair well on heavier cars like the raddo but are fine on the lighter golfs :? Just an observation I have made! Quote Share this post Link to post Share on other sites
khurrado 0 Posted February 8, 2006 yeh thats probably true actually. And also if u do get them, ull need 20mm lower springs at the back to get the car level. Quote Share this post Link to post Share on other sites
tarche2 0 Posted February 8, 2006 hence the 80 / 60 setup I was running! Quote Share this post Link to post Share on other sites
khurrado 0 Posted February 8, 2006 ahah. I need to get 60mm springs for the back of my corrado to drop it as well. Quote Share this post Link to post Share on other sites
tarche2 0 Posted February 8, 2006 Pics of my golf 80mm back 60mm front gmax shocks and springs! Quote Share this post Link to post Share on other sites
matth76 0 Posted February 10, 2006 I wish GMAX did springs that lowered my golf mark 3 vr6 more than 35mm. All the spring shock kits out there only lower the car a max of 30-35mm. Koni and H&R spring shock set ups only lower the car about 25mm. I did find a JOM kit which uses Koni dampers and lowers the car 45mm but no one anywhere has heard of them unfortunately. I'm not going to risk it on "unproven" suspension. I'm after new suspension to really improve my handling but also actually make the car look lower. 35mm will make my car look lower than it already is unfortunately. Hence I am going to have to look for coilovers of some kind. What I'd really like is an H&R suspension kit that lowered my car at least 40mm on just springs and shocks. However only their coilovers do this. Bit out of my price range at £950 to supply and fit! Are there any spring shock kits out there that lower the golf vr6 more than 40mm that are any good? Quote Share this post Link to post Share on other sites
redcorrado 0 Posted February 10, 2006 fk coilovers Quote Share this post Link to post Share on other sites
W3RKD 0 Posted February 10, 2006 We can supply a KW Tuv approved -40mm kit for your golf for £325.00. Would you want to go alot lower for everyday use ? Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted February 12, 2006 I've had a Vipertech kit, bought from Venom, on for 3 years or so and i've not had any problems at all, they've a lifetime warranty too. -40mm was around £280 i think. We can't all afford £5-600!!! Quote Share this post Link to post Share on other sites
