pukka96er
VR6 ENGINE CODES!!!
i am trying to replace my 1992 k reg corrado vr6 abv engine and finally found one at a breakers !!!
i then found there are two types distributer and coil pack they had both but then apparently there are more differences as mine has not got "aaa" on the chassis number please if someone can shed any light on the subject ????
Mod Edit:De caps'd
The ABV engine is the 2.9 fitted to the Euro spec Corrado, the AAA engine is the 2.8 engine fitted to the Golf and the US spec corrado.
Early VR6 engines (both ABV and AAA) had dizzy's fitted, later ones had coilpacks. I'm not sure when the changeover from dizzy to coilpack took place, although yours (1992) is an early VR so I think yours would be a dizzy type.
My '94 L-reg VR has coil packs rather than a dizzy, if that helps, but not an ECU with a built in immobiliser, that was only on the last cars I think, 1995 ones.
