AB
16v inlet manifold
hi needing some advice on this inlet manifold on ebay item 4613541846. it is a shortened manifold so the 4 branches have been cut down to next to nothing. what effect would this have on my engine worth getting or not. any advice welcome.
just had a look sounds like the seller has had a few? will pro do what he says but dont think it will give that much of a change, its gonna reduce drag and improve air flow because the air has less distance to travel. if you do buy it let me no if it made a difference.
i will bid on it. yeah if i get it i will let you know. dont know how neatly it will sit on top of the engine with the leads and everything.
wouldve thought it would be pants.The longer the runner,the more torque you get.
Would be ok for forced induction but id steer clear
ok will take your word. i was unsure of it cos in your tuning guide you say fit the bigger 50mm one. will leave this thanks.
