Madjackal 0 Posted February 22, 2006 Are these the same for all models? Quote Share this post Link to post Share on other sites
Madjackal 0 Posted February 22, 2006 damn, there's one going on ebay cheap only i think its list VR6,G60 and valver. Quote Share this post Link to post Share on other sites
RW1 0 Posted February 22, 2006 Types for the UK, ABS only, ABS + EDL (Traction Control) Read the bottom of this thread. :oops: doh, it helps if I press the "paste" button http://the-corrado.net/.archive/forum/viewtopic. ... highlight= . Quote Share this post Link to post Share on other sites
h100vw 0 Posted February 22, 2006 Which part number do you need madjackal, I have a G60 Golf one in my garage you can have cheap if it is the right one. Pretty sure it's a non-EDL one. I have ETKA so can check the numbers out. Do you know what's up with your ABS? Gavin Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 22, 2006 He's got a VR... Quote Share this post Link to post Share on other sites
Madjackal 0 Posted February 23, 2006 i dont think there is anything wrong with mine, i think its the sensors as the light has only started coming on since i have been messing about with my brakes. Its just odd cos its intermittant?? I just saw the one on ebay and thought as no one had bid on it i could get one dirt cheap, and bearing in mind the cost from the stealers....... Quote Share this post Link to post Share on other sites
h100vw 0 Posted February 23, 2006 The ECU stores faults I think so maybe you can get them read with VAGCOM? A wheel sensor is likely to be duff as you say. Have you done all the brakes? You could try disconnecting and re-connecting all the plugs and a quick sqirt with some contact oil from Maplins or RS? Works great on Aircraft!! :mrgreen: Quote Share this post Link to post Share on other sites
RW1 0 Posted February 23, 2006 The ECU stores faults I think so maybe you can get them read with VAGCOM? yep Plus measure the resistance of the as 1kohm +/-300ohms. Front sensors can be done at the wheel hubs. Rear have not connection at the wheels, the plug break is under the the left and right rear passenger seat squabs (bit you sit on). . Quote Share this post Link to post Share on other sites
Madjackal 0 Posted February 23, 2006 thanks chaps, The rear n/s sensor is new and ive done both front brakes, i'll see what the vagcom comes up with and go from there. Bloody sensors! always let you down when your saving up for something else. Quote Share this post Link to post Share on other sites
RW1 0 Posted February 23, 2006 When you did the front brakes. Do you mean the discs were replaced. Did you transfer the ABS sensor trigger rings of the inside of the discs????? . Quote Share this post Link to post Share on other sites
Madjackal 0 Posted February 24, 2006 i changed the pads and discs but left the original trigger rings as they were Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 24, 2006 I don't think it's necessary to replace the front ones is it?? I know with the rears it is as they are more fragile and can distort... Quote Share this post Link to post Share on other sites
Madjackal 0 Posted February 24, 2006 havent touched the rear brakes anyway, I think the ring was slightly distorted and rubbing slightly on the sensor on one side iirc. I'll get stealth on it when i take it up, Steve can you let me know when you placed my order please buudy? Cheers Quote Share this post Link to post Share on other sites
Madjackal 0 Posted February 24, 2006 sorry meant to say "when you have placed my order" Quote Share this post Link to post Share on other sites
