stuartnigabbain
Corrado 2.0 16v - Engine cutting out
The engine is cutting out intermittantly when at low revs, for example when approaching a roundabout or junction. When using clutch the revs drop and engine cuts out. The car will always start directly afterwards.
I have tried:
Cold start idleising valve
New High Temp Leads
Throttle Body cleaned.
Hoses replaced
Placed on computer at garage (no probs)
Any ideas gratefully received????? Thanks
Do you mean the Idle Stabilisation Valve?!
Start by checking that the throttle is adjusted so it's closing the closed-throttle switch on the throttle body. That's the signal to open the ISV.
