flusted
Gasflowed 16v throttlebody with 3mm overbore
Im sure some of you are aware of a chap named ian who can modify vr6 throttlebodys by machining and fitting a larger butterfly.
Ive just had a 16v 1 done by him and the work is amazing!
I sent him my spare tb,he bored it out then fitted a 3mm larger second butterfly.
He had it done and returned to me in just a few days 8)
Since ive had it back,ive match poted the 2 halfs together,shaved the spindle down in the small butterfly and fitted counter-sunk screws.
When i flowed the front half,i took into consideration that the air doesnt hit the tb straight on on a 16v,so i shaped the divider for this and knife edged the divider between the ports.
Its not completly finished yet as i need to fit shorter screws in the second port and polish the whole thing but heres the pics so far
Ian can offer a similar service for £120,this gets you your tb machined out and the larger butterfly his emal is mailto:[email protected]
