King_prawn 0 Posted September 2, 2003 Any one running a second inlet on their G60? Just thinking about removing the boost return pipe but seems like a bit of a waste to cap the inlet off. Any one got a pics? Cheers, Rob Quote Share this post Link to post Share on other sites
G60 0 Posted September 2, 2003 i agree.. a waste to cap it but thats what i did anyway. at least it saves the charger from all that extra heat until i get a proper 2nd intake worked out. if you're going to do a second inlet, get the air from a cool place or its useless. i'm planning on dropping the rad down and bringing cold air in right through the top of the grill. you can also run a pipe down into the fender under where the battery was (you'll have to move it and cut a hole)... like on the opposite side with the carbon cannister. you can just stick a filter on there but if its sucking hot air its basically useless. darren/g-werks has some pics and i believe he's working on a kit :D Quote Share this post Link to post Share on other sites
mambomonkey 0 Posted September 3, 2003 Having removed my boost return pipe iam just about to sort a second inlet. Have just got a blanking plate on there at the moment but i've heard that this puts uneven pressure on the charger's internals. A quality direct cold air feed is what you want really. I'd like to get a BMC Carbon Dynamic airbox if i can find a correct diameter pipe, and run it down under the bumper. Just money permitting as always... :oops: Quote Share this post Link to post Share on other sites
G60 0 Posted September 3, 2003 is there room in there for that mambomonkey? i've looked long and hard at my C and there's no room to run a pipe down to the bumper area. i have a/c... that was my backup plan... if i couldnt figure anything quick and easy out for a cold air feed to that inlet... i was gonna run a pipe down to the bottom... just no room so hacked out a blockoff plate. im gonna drop the rad and feed cold air in through the top of the grill. thats the plan anyway. Quote Share this post Link to post Share on other sites
