gus16v
what brakes can I run???
What is the largest front brake disc I can run on my standard 1.8 16v G reg corrado calipers??
Cheers
256mm using the carriers that you have, you can use 280mm's using g60 carriers
to go bigger you will need new wheels and calipers/carriers(something like seat ibiza cupra R brembo's would be perfect but you need 16's to fit them behind
G60 brakes arent expensive.. you'll need the calipers, discs & pads..
check out the for sale section or ebay!
Bigger brakes have been discussed quite a bit - have a search and you should find the list of many, many options ;)
(bear in mind the VRs are 5-stud, not 4-stud).
Lockaroo
