matth76 0 Posted March 14, 2006 How good are "Eurospec" 268 cams? They are half the price of Shrick cams but I've been told they are basically copies of Shrick cams. Are Eurospec cams very good quality and will they produce similar linear power outputs that Shrick cams do (as opposed to other cheaper makes of cams which only produce increases high up the rev range)? Is it risky going for second hand cams or should I only go for brand new ones? I have found someone selling theirs that are 8 months old with 2k miles on them. Thanks for any help. Quote Share this post Link to post Share on other sites
flusted 0 Posted March 14, 2006 cams very rarely wear unless the oil pump fails.so buying secondhand shouldnt be a prob Quote Share this post Link to post Share on other sites
matth76 0 Posted March 14, 2006 Thanks. Are Eurospec a good quality make... are they better than Piper or Kent cams and as good as Shrick? Quote Share this post Link to post Share on other sites
rmn 0 Posted March 15, 2006 eurospec are top quality stuff! they even made a new head for the G60 block Quote Share this post Link to post Share on other sites
matth76 0 Posted March 25, 2006 Ok... I've just bought second hand 268 Eurospec cams for a golf vr6. I have been told they have done approximately 2k miles. They are silvery grey and I have noticed there are some random grooves/nicks right all the way down one of them... it looks as though it is from wear and tear, and also some strange reddish speckling on one of the 'lobes' where it would normally be silver... my question is will cams normally have a some scuffs and nicks like this etc if they have done around 2k miles?.. I assume they will if they are right in the head of the engine... but need to find out what these nicks are all the way down one of them. Also should the word "Eurospec" be written anywhere on the cams? Thanks for any help. _________________ Quote Share this post Link to post Share on other sites
keithmac 0 Posted March 25, 2006 Best bet`s to post a pic of the cam so we can have a look. Quote Share this post Link to post Share on other sites
matth76 0 Posted March 26, 2006 Hi guys, thanks for your messages. There doesn't seem to be any wear on the lobes themselves (although there is some strange red colouration/speckling where it would normally be silver - not sure what this is) but the actual grooves/nicks (which are only the size of the end of a small screwdriver, are all the way down the actual cam length.. the other cam length seems fine. I will take some pics when the weather clears here and post a link..it may be a day or so though. If the cams are ok for use I will be certainly using new followers/tappets...is this a good idea or will it make the wear on the cams worse? Quote Share this post Link to post Share on other sites
